Old 09-06-2017, 12:52 PM   #2
PaulE
Did you get the male pieces on the hardtop into the spinlocks before you turned the levers? If so, there is a triangular plastic piece on the inside of the hardtop on each side right above the spinlock. Pry those covers off, and you will see 3 Allen bolts that can be loosened so you can adjust the top forward and back and up and down. It looks like you need to go down. I can't really see on the picture, but it looks like you have a 1/2" gap between the top edge of the clamshell and the bottom edge of the hardtop. There are posts somewhere that show the adjustments I'm talking about. I tried to search for them but didn't come up with them.
