Thread: RPM fluctuation
Old 09-05-2017, 09:28 AM   #14
mountainman
mountainman's Avatar
well, I have been working on my RPM fluctuation for a while and no change. It still does it at cruise speed ( anywhere between 1800 and 2200 rpm I get about a hundred rpf flux ). below or above everything is perfect. no other symptoms. I have cleaned the throttle body and changed the maf, oxygen sensors and aos. These were well overdue for a change anyway. I did a smoke test and found no vacuum leaks. I am wondering if the throttle position sensor or fuel injectors would give these symptoms. At 104K miles I am sure it could benefit from new injectors. Any thoughts? It is a 2004 boxster s with tiptronic. It does it in auto mode, or in any gear in manual mode and it does it with cruise control on as well..
mountainman is offline   Reply With Quote
