Old 09-05-2017, 06:00 AM   #2
edc
550 Anniversary
edc's Avatar
Originally Posted by mikefocke View Post
You know the problem is with the airbag because the codes tell you that it is?
Most airbag lights are grounding issues. There is a TSB on this for the buckles and ground straps.
To pass the MOT in the UK the airbag light has to come on then go off. If it stays on then obviously we know that indicates a fault but it won't pass an MOT irrespective of what the actual fault it.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
