Old 09-04-2017, 10:09 AM   #13
AZ986S
AZ986S's Avatar
Clogged pick up tube?
Thanks.
I dropped the sump plate when I installed the EBS oil baffles about 6 months ago and it was pretty clean in there, but off course, there could be sealant in there now after re-sealing...
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
