Old 09-04-2017, 06:16 AM   #15
harnishclan
harnishclan's Avatar
Originally Posted by mikefocke View Post
Have you identified a common cause for the engine failures?
Completely different. First motor lasted two event after I bought the car, poor maintenance is likely as the first oil change was bad. Ate the main bearings. Second motor (used no history) lasted 10 events and broke timing chain coming out of turn 9 at Houston Motor Sport Ranch. ALL valves are open and about half are bent.
Considered a deep sump with baffles, oil pump kit, etc or was that part of your rebuild?
Mantis 1.2L pan, S oil cooler.
Originally Posted by Flavor 987S View Post
And install a magnetic drain plug. L&N makes a good one. Torque spec is very low. 19ft.lbs. FYI
Done
Contact the shop who did the rebuild. They should have a recommendation for the break-in procedure for one of their engines.
While very experienced, he just did the M96 class and doesn't have solid info to run in a track motor.
Q's advice is good but it is good for a Track car.
Many will miss that in the first Post.
For a road car, less extreme oiling upgrades may be sufficient.
Its a track only car, heading towards SPB (though budget and build slightly derailed by an extra 10K in motors) so there are limitations to what you can modify. Dry sump might be a step too far. Accusump is about as far as it seems you can go.
Brian
Current: SPB Boxster, Macan S, 1984 944
Past: 10 944s, 2 924 Turbo, 911SC, 993, Cayenne, Boxster S, and Cayman S.
Future: 356C
harnishclan is offline   Reply With Quote
