If its loosing coolant, you could ideally run two tubes from under the driver and passenger seats up to the water pump. Car needs to be parked outdoor for this mod to work. It would refill your coolant tank periodically and protect the immobilizer at the same time.
Sorry to be sarcastic, read 'bladder problem' and couldn't resist. Sorry.
Hope your indy will be able pressurize that misbehaving cooling system for you this Tuesday and let you know what's wrong with it. Luck man
