Old 09-03-2017, 05:43 PM   #94
JFP in PA
A system pressure test takes about 5 min to do, and will immediately tell you where you are. It does require a special tool and the correct adaptor to attach to your tank (the adaptor is for a VW), but will immediately tell you if your cooling system is closed up or open to the atmosphere. I suspect that is where you are.
