Old 09-03-2017, 06:33 PM   #92
JFP in PA
OK, first of all, calm down. No, the tank is not under pressure when the car is cold. But I have some concerns that unless the lines that broke in the first place were correctly reconnected, you have been chasing your tail. If memory serves, you broke the line leading off the top of the oil cooler; if that line was not correctly reconnected to the tank, coolant is going to flow all over the place as soon as the car is started.
I would most strongly recommend you get your cooling system pressure tested. That will immediately tell you if it is tight or not; I suspect it is not.
