Old 09-02-2017, 10:17 AM   #11
robdelorenzo
I am beginning to believe that the water pump impeller melted or broke based on the fact that there is a fine black powder in the bottom of the coolant tank now that it's cooled off overnight and is only about 1/3 full.
Do I try bleeding it first?
What do I do?
It's become a money pit and I think that I may have a clogged cooling system as the mechanic suspects from the meltdown.
Any advice?
Junkers will give me about $1500 for the car.
Is it worth putting the kind of $$ into it to see what's going on?
It's a 2002 with 145k that was run while completely overheated. It seems to me that even if I do get the coolant thing sorted out, are there cracked heads or cylinders in my future?
Is this the type of scenario where the temp gauge will not register a problem as going above 190 but if there is no circulation, the temp is actually a lot hotter and then that is causing the overflow to dump coolant once it gets hot?
I'm trying to stay logical and reasoned without losing my mind here.
robdelorenzo is offline   Reply With Quote
