Originally Posted by MikenOH
I've seen a few of them but have not had the opportunity to drive one. BTW, the fuel economy increase was pretty significant--20-23/city; 29-32 highway. A 10%+ bump which is pretty significant.
...which didn't surprise me. I went on a fairly lengthy drive, (about 25 mi) over all sorts of roads - in town, parkway, two lane semi-rural route and interstate as well. A good opportunity to get to know the car. Motor sounds great, as expected, if not quite as visceral as the 3.4. By the same token, noise was not obtrusive cruising the interstate either, which concerns me a little about the 3.4, based on a shorter drive I had with it in winter - didn't get it out on the highway. Variocam Plus definitely smoothes out that curve a little further - it steps off the line nicely, and in gear, it gives you what it has pretty much right away, so response is good; it digs out nicely from low rpm, too. The only problem is that it just doesn't HAVE all that much, in terms of torque. My chipped 2.0T GTI blows it away in terms of output, and while it would struggle in a sprint, being FWD, I think in gear, the Cayman might not be able to keep up despite being lighter. My modded 1.8T TTR also has more torque; that might be a close contest; but I digress...in summary, if you liked the old 2.7, you'll like this one just a little bit more. One question for you guys who bought your Boxsters new - how much do Porsche motors loosen up during (and after) the formal break-in period? Is there a noticeable improvement in response and elasticity? TIA for anyone who can shed some light.
Anyway, I really love the Caymans' - I think they are probably the sexiest thing on the road right now - I like them enough to consider unloading both my cars and foregoing the Roadster experience I was planning to continue, going from the TT to the 987, as I mentioned in another thread. I think with a Boxster, I could be very happy with the 2.7, because that car is fundamentally about the Roadster experience, and raw power and speed are less important to me in that context. It's about all the things you can see/do/feel/smell with the top down that you don't with the coupe. PLus, going Boxster would allow me to keep my GTI as a daily driver, which is probably alot more practical. If I go Cayman, I think I'd need the power of the S to keep me entertained, and I'd have to unload both cars for $$ reasons, plus the Cayman is probably more able than the Boxster is (IMO) to fill the dail driver role.
Other notes on the test drive, to get back to your question: salesman mentioned there was a recall on the bump stops for the hatch - they were not allowing the thing to shut properly somehow, and the hatch rattled quite a bit, even with a metallic clang over rough stuff. Seems to be an 07 Cayman only issue. No biggie. The stock 17s were quite a nice ride handling compromise, and certainly enough to handle what the 2.7l can throw at the chassis, IMO. Love the look of the Cayman S 18s, but they may be overkill on the 2.7l, and even take away some of the cars fluid handling feel, I fear. Probably why they are OE on the S, not on the 2.7...
On a related note, I also found that insurance is only a little higher than for my TT, and that Cayman's are only slightly more expensive to insure than Boxsters, at least with GEICO. So that is a plus for me...
My final thought on the car came a day after the drive - you could argue that the Cayman, especially the 2.7l, is the closes thing to an old-school Porsche sports car; it's very compact, relatively light, does not have overwhelming power, huge running gear or AWD or turbocharging or anything like that; and lastly, it's a car that is fundamentally about the agility, responsiveness and fun of it's chassis.
That's my 2 cents.
So what should I get?????????????????????????????
