			there is an overflow tube located by passenger rear wheel. I think that there might be air trapped in the system and it has to be bled. Wait for the experts to chime in. In the meantime do search air trapped and how to use the bleeder valve on top of coolant tank. Again I could be totally wrong but I have been down that road. How much coolant?They say to drive thru a couple heat cycles with valve open. My solution was to back up on ramps and run to purge....worked great. Good Luck and I am sure you will be fine soon!
