Old 08-30-2017, 04:09 PM   #13
Smallblock454
Hello,
a brake system with ABS has an ABS regulator block (don't know the right english term for that part). The conventional bleeding method by just hitting the brake pedal while sombody else opens and closes the bleeder valve doesn't work with that. So i recommend to use a pressure system to bleed brakes and clutch.
Regards, Markus
