Old 08-30-2017, 09:05 AM   #10
seningen
seningen's Avatar
Originally Posted by Qmulus View Post
It is just semantics, but the alternator clutch/pulley did not shear off, it spun off. If it had sheared the shaft, you would have a snapped off alternator shaft. It looks to me like you could just install a new clutch/pulley assembly and it would be OK. The alternator has a one-way clutch on it so it will continue to spin and not throw the belt when you shift. This is kind of unique and not usually seen on other cars. What may have happened is that the clutch seized (they do fail occasionally) and when you shifted the momentum of the alternator unscrewed the pulley from the shaft and the pulley fell away. Normally the one-way clutch would slip in that situation, as it was designed to do. After that, the temperature and pressure in the cooling system got so high that the weakest point failed (that plastic fitting) and the cooling system blew. I don't understand why the cap wouldn't vent though...
That is my theory anyway. I bet if you look where this happened you will find the pulley pretty much intact on the street.
This was my point -- it did not look like it sheared to me...
My guess is you will be back on the road in no time --
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
