Old 08-29-2017, 02:49 PM   #1
Coaster
Coaster's Avatar
Originally Posted by bwdz View Post
What does the freeze frame pull up? It might give you a hint as to what was happening when the code was triggered.
Be gentle, I'm learning. What freeze frame? Can you explain this in simple terms. I don't have the data, the shop does. I'm looking for a blue tooth reader to record active data so maybe I can capture itat the moment it flashes.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is online now   Reply With Quote
