Old 08-26-2017, 06:40 PM   #17
bwdz
How do you ensure its within the mV rated range? Fluid sensors needs a pretty sharp resolution to function to specs, no? Was under the impression only a computer was geared for this sort of accuracy. Mind you if one have a industrial grade multi-meter then it might be doable. Really dunno... excuse my ignorance on the subject, never done it. Interesting stuff
Warning: requires 10 mega-ohms independence multi-meter on Porsche cars (and Prius). To prevent drawing too much current and damaging the other end, something like that
Porsche are complex things! Love it tough...
You won't get "accurate" readings with just a simple voltmeter. You can however determine if it is "dead" if you get something similar to nearly no voltage that his scanner is reading. It is a little easier to do on the secondary o2 as it's voltage should be much steadier than the fronts. If you have a fancy meter or a scope or even a high low min/max meter that is a little better. All the reading should be done after the car is warmed up, the heater circuit can malfunction on the o2 and cause problems as well.
bwdz is offline   Reply With Quote
