Did you use Alpine components? Where did you mount your crossovers?
There aren't many amps that will fit where the stock amp is. What model amp did you purchase?
You'll have no issues wiring directly to the factory wiring - the signal (rca) wiring was a bit tricky in my 02 with Bose, if I recall.
In my car, I used the OEM amp housing to mount a signal processor, and I used the OEM plug to interface to the car's wiring.
