Thread: Swapping seats
Old 08-21-2017, 06:39 PM   #2
KevinH1990
KevinH1990's Avatar
Originally Posted by kooze1948 View Post
Will removing cushions allow access to the seat adjuster electrical connection? Trying to install new switch.
Here's the link to the process for disassembling a 2-way power seat:Boxster Seat Disassembly Procedure Part 1 of 2
It is written with the assumption that you have the seat out of the car. However, it may be possible to remove the seat bottom with the seat in the car. If you can remove the seat that will give you better access to everything.
Is your seat jammed and you cannot move it backward or forward in order to remove it? If you have 8 or 12 way power seats, the process is actually a little easier than for two-way power seats. If you absolutely must remove the seat bottom with the seat in the car you can remove the 2 small screws that hold the seat controls to the side of the seat. (There is no need to remove the height adjustment switch as with the two-way seat.)
You can then remove the control panel by lifting it up. (The top part hooks into the leather and you will need to carefully wiggle it loose.)
If that doesn't give enough access, you can unfasten the two white plastic clips under the front of the seat bottom as shown in the link.
I hope this helps.
