Old 08-19-2017, 10:37 AM   #10
Gilles
cure for a noisy lifter..?
If you suspect build up, long before I would dump any aftermarket product into the engine, I would switch temporarily to a diesel oil such as the Shell Rotella T6, which is a 5W-40 0il that is both very high in detergency (required in a diesel) and in ZDDP (diesels do not have cats, so they can run high ZDDP).
When you change the oil after 3-5K miles, it will be ugly, but that is what you want.
JFP,
Sometimes, I get a noisy lifter when the engine is warming up, do you think that switching (temporarily) to the Shell Rotella T6 somehow could help to clean the lifters?
My engine has a bit over 100k and other than the occasional lifter noise, it runs pretty smooth (Been changing the oil @ +/- 5k miles since new)
As always, thank you for our comments.
