Old 08-17-2017, 07:04 PM   #12
MarkAP
MarkAP's Avatar
Dwight's OBC harness
Originally Posted by por356c View Post
Hello - if you're going to do this project, be sure to purchase the OBC wire harness from pdwight. It's perfect, affordable and will save you a lot of work fabricating one as the hack instructions will tell you to do. In addition, if do not have cruise control, pdwight has a harness for this too and you might as well do both at the same time. These projects are detailed in Pelicans website - 101 Project Book, projects 91 & 92. I just did both projects this past weekend. The biggest asset I had was pdwight's excellent harnesses. Good luck.
I want to second this. Just installed the OBC using the wire harness from Dwight. Very happy with it. Looks highly professional and comes with color instructions that are very clear. Thank you Dwight!
Mark
Guards Red Boxster S, born in Germany May 2004. LN spin on filter, litronics, roll bar mesh, wind deflector. Pioneer AVH-4200 hu, rear shelf box with speakers installed. 36k miles.
MarkAP is offline   Reply With Quote
