Old 08-17-2017, 04:03 PM   #11
por356c
OBC Hack Projects
Hello - if you're going to do this project, be sure to purchase the OBC wire harness from pdwight. It's perfect, affordable and will save you a lot of work fabricating one as the hack instructions will tell you to do. In addition, if do not have cruise control, pdwight has a harness for this too and you might as well do both at the same time. These projects are detailed in Pelicans website - 101 Project Book, projects 91 & 92. I just did both projects this past weekend. The biggest asset I had was pdwight's excellent harnesses. Good luck.
David Preston
2008 Cayman S
por356c is offline   Reply With Quote
