Old 08-15-2017, 01:46 PM   #6
Gilles
Originally Posted by Snipershot View Post
The exhaust does shake. Its actually came loose from the muffler twice now. I watched some youtube videos, and it doesnt look too difficult. So you would just change the insert? There probably isnt anything to gain by replacing the whole bracket, is there? Ive seen several brands also, so im guessing one is as good as the other? Thanks for all the info!
Joe
Joe, one advantage of replacing the complete mount (insert and bracket) is the time as otherwise you will have to remove the bracket and take it to a press to remove and re-install the insert (unless you have a press in your garage)
However if you replace only the insert, you could save between $75-$100 (..?)
Gilles is offline   Reply With Quote
