Old 08-15-2017, 01:41 PM   #159
78F350
Motorist & Coffee Drinker
78F350's Avatar
Cooling Fan:
I am using the standard DC Fan #3010 bolt pattern therefore, and shall you need to service the unit in 2~3 years loll (i.e. replace the fan), ...
Oh no! Another IMSB. Is there a way to know the fan bearing is going out before it causes catastrophic shrapnel and ignites the dashboard? I'm thinking you should make it a plain bearing fan with an oil feed from the engine. ..or perhaps tap into the low pressure A/C line and use a micro-evaporator for proper cooling.
As always Fred, amazing work and sure to be better than anything commercially available. Any reason why I shouldn't get one to replace the PCM unit in my '05 Cayenne?
