Originally Posted by Gilles
if you hear knocking behind the seat when you bare backing up, most likely you have a bad engine mount.
But if you change it yourself it's actually kind of cheap (the insert only)
by using search, you should be able to find here few step by step procedures.
Good luck!
PS: Ask someone to watch the exhaust pipe while your are backing up, to see if it jumps up and down..
The exhaust does shake. Its actually came loose from the muffler twice now. I watched some youtube videos, and it doesnt look too difficult. So you would just change the insert? There probably isnt anything to gain by replacing the whole bracket, is there? Ive seen several brands also, so im guessing one is as good as the other? Thanks for all the info!
Joe
