Have you tried adjusting the rubber bumpers. There are two - located on each side of the of the front edge of the hood. Turn them all the way to the right and see if that gives enough clearance for the hood to latch. There is some up and down adjustability in the latch assy. You may need to raise the latch assy. for the hood to latch completely.
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
