Old 08-11-2017, 12:14 PM   #7
Gilles
coil over height
After installing the KW-V3 coilovers I took my car to get it corner balanced at Steve Alarcon alignment shop (SoCal), he is a member of the POC and has great reputation.
After 95k miles, I replaced the lower control arms, also removed the KW-V3's and send them to KW to get them overhauled and I used the same ride height as when got the corner balanced (Steve mentioned that as long I get the same ride height again, the end result should be the same)
I have the heights from the original settings (after corner balancing), I can share them with you if you want, these should help you to get a starting point.
Please note I have a Cayman, therefore the weight may be a little different from the Boxter one but should be in the ball park, please let me know.
Good luck.
