Thread: Radio code
Old 08-11-2006, 01:12 PM   #5
MNBoxster
Hi,
A Dealer is likely to charge you for the code (I've seen $65 charge for this), especially if you didn't buy the car there or aren't having any other service performed. You can retrieve the code if you have the radio serial number which is on a sticker on the radio case (will need removal keys (something like $5) and slide the unit out slightly). Then take the serial # and go to: http://www.radio-code.co.uk/ follow the links for Becker and you'll get the code. Hope this helps...
Happy Motoring!... Jim'99
