Old 08-11-2017, 06:00 AM   #1
JFP in PA
Your comments about no idle change and strong suction tells me you probably need to start with the AOS. The best diagnostics for the AOS is to used a digital manometer connected to an oil fill cap to measure the vacuum level, which should never exceed five inches of water (a relatively weak vacuum signal).
