Thank you for the advice. I'll have to make sure I order the top mounts adjustable rear to control arms soon. I was planning on going with oem Porsche for the top mounts. I will need new tires probably in the next 5000 miles or so and want to go wider than the stock 205 front width.
I appreciate the advice on how to install the coilovers. Will adjusting height mess with the corner balance? I'll have to see what some of the popular height settings are and figure out what will work best for me. I have also heard about setting the rear a little higher as far as ride height. Now to search for some alignment specs!
