Old 08-08-2017, 05:00 PM   #12
Qmulus
inveniam viam aut faciam
Want quick, easy, and cheap? Grind a fresh surface for adhesion and J-B Weld a small strip of aluminum on. J-B Weld can fix everything.
Want it done right, safe, and permanent? Replace it.
THIS^^
Honestly, if you don't want to replace it, that is probably the quickest, cheapest and easiest method, with little risk that you can do yourself. If it doesn't work, no harm done.
That said, replacing it is the best option.
Qmulus is offline   Reply With Quote
