Old 08-08-2017, 02:37 PM   #5
Bobiam
Bobiam's Avatar
Try to isolate potential culprits..
Disconnect clutch switch and jumper the two wires together. If no improvement, reconnect the clutch switch and replace your ignition switch ($15).
Also look at battery cable connect
Easiest things to eliminate and most often the cause of the problems before moving on.
Thanks dghii..... Good logic. Is this clutch switch under the dash or under the car???
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
