Old 08-08-2017, 01:26 PM   #4
dghii
Try to isolate potential culprits..
Disconnect clutch switch and jumper the two wires together. If no improvement, reconnect the clutch switch and replace your ignition switch ($15).
Also look at battery cable connect
Easiest things to eliminate and most often the cause of the problems before moving on.
dghii is online now   Reply With Quote
