Old 08-08-2017, 07:45 AM   #1
JFP in PA
Originally Posted by IrishMike View Post
Current fault code 8004 terminal 50.
It also lists part number 997.618.172.12
Any thoughts?
This fault means “Supply voltage at terminal 50” this was often caused by a disconnected battery or an internal failure in the PAS control module. Porsche Access System PAS Module: P/N 997.618.172.12
If the PAS module is bad, a new one is around $430 at retail, and requires the use of a PIWIS to recode to the car.
