I had my ignition switch fail as well. What clinched the diagnosis was that everything (notably the AC, but other electrics as well) would work properly if instead of letting the switch spring back to its running position on its own I manually tweaked it and found a position where everything worked again. Not a hard job, but a pain in the butt as access is tight. Search the forum for tips and techniques if it is the switch
