Old 08-06-2017, 03:22 AM   #17
Antonio
ACSF
Send a message via Skype™ to Antonio
Pete I bought this same 996 wheel & tire package from a Porsche dealer because they were out of the Boxster pkg for my 2000 "S". The dealer included a pair of 24mm spacers which allowed the rear wheels & 285 tires to be mounted & driven but the tires were so close to the outer fender under hard cornering the 285's would rub the fender. This setup gave about 8mm clearance from the strut so I believe about 20mm spacer would be better. If you try that & have tire clearance issues you can still do like I did & sell the 285's & run the ideal size which is the 265 width.
Hi BYprodriver,
I have the same question I bought for my Boxster 2.7 2000 the same pack of Carrera Wheels BBS 18'''
Front 7.5 ET 50 tire 225/40
Rear 10 ET 65 Tire 265/35 Old Topic same question sorry , but I need to clarify****
In the front I don't have any problem
In the Rear even with a 20 MM Spacer it looks very close from the suspension :/ (few mm) is that OK ??
Appreciate any HELP !!!!
Antonio is offline   Reply With Quote
