Old 08-05-2017, 01:32 PM   #2
JFP in PA
Originally Posted by achillies View Post
My car has OEM Litronics. 03S. Using Durametric I can move them center/up/down
The headlights come on and go to hi beams
Durametric comes up with the following faults (the actual fault numbers are 1,2,3,4,5,6)
1. Engine Path Left
2. Engine Path Right
3. Axle Position Sensor – Front
4. Axle Position Sensor – Rear
5. 5v Supply Axle Position Sensors
6. Control Unit Coding Error
Is there something I should do?
Bob
You have just about every Lit code possible, but the big one is the last one: Control unit coding error. This means that the DME cannot communicate with the Lit control module. I would look for a wiring problem or loose connection first, it that is not it, you may need either a new module or get the old one recoded, which requires a PIWIS.
