Old 08-03-2017, 03:07 PM   #5
lkchris
lkchris's Avatar
Just in case ...
Many are mislead by the 101 Projects book that this mod requires removing steering wheel, etc.
In fact the lever for OBD bolts to the switch cluster and the entire switch cluster does not require replacement. So, if you can find a used switch cluster, just remove the OBD lever from it and fasten it to yours. The advantages being you have a logically marked switch plus you get all OBD functions.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
