			Just in case ...
 Many are mislead by the 101 Projects book that this mod requires removing steering wheel, etc.
 In fact the lever for OBD bolts to the switch cluster and the entire switch cluster does not require replacement.  So, if you can find a used switch cluster, just remove the OBD lever from it and fasten it to yours.  The advantages being you have a logically marked switch plus you get all OBD functions.
				__________________Kent Christensen
 Albuquerque
 2001 Boxster
 2007 GL320 CDI, 2010 CL550
 2 BMW motorcycles
