Old 08-03-2017, 02:06 PM   #1
911monty
911monty's Avatar
Originally Posted by jpc763 View Post
I have some good bicycle lube. Prolink Bicycle Chain lube. I assume that I just squeeze a bit into the latch mechanism. Any particular location?
You want to get the lube onto both sides of the latch pawl so that it spreads to the housing. If you look closely at the slot in the latch housing you will see the latch. to the right is the rivet it rotates on try to get to there.
