Old 08-03-2017, 10:39 AM   #11
That986
Blah, blah, blah, about what I expected. I was wondering when the united ims replacement front would show up.
Can we actually get back to the thread in hand and pass on the "omg you better replace it now" comments?
The comments below may only apply to an M96 with exactly the same IMS-related tolerances as the hyundai beater cited.Your engine may be different - better or worse.That is the essence of the M96 IMS issue - multiple mechanical variations leading to unpredictable failure. Postmortems can give an explanation of some of the proximate causes of failure.Driving style is cited but only in a few of the contributory factors(e.g. acidity in lubricant).
The IMS research findings on this Forum are that M96 engines vary in critical dimensions and tolerances. The more adverse tolerances your engine has, the sooner the bearing will fail.
Chest-beating comments like 'drive it like you stole it' do not frighten out-of-round IMS tube measurements into obedient concentricity.
The recommendation below may hasten IMSB failure(and other weak components) but according to the recommendation below .the car will die happy. We may be muddling Mechanical Engineering and collective Forum wisdom with Anthropology ?
First, do no harm.
Second, find a competent,honest Indie.
It is all in Search.
Yemv
That986 is offline   Reply With Quote
