I installed a "S" cooler on my '97 2.5 (tip tranny). I had to use the adapter plate (which was not originally on the car - had to purchase it plus the cooler). The new cooler has the vent on top and the '97's do not have a connection for it so I simply plugged the vent (used a rubber plug and hose clamp) that has worked for 2 years including some track time and all is good. I am not sure the addition of the "S" cooler really helps much - it is not much larger than the stock unit (at least on my '97 tip). It might help if your original cooler is clogged or comes from a car that was neglected.
