Originally Posted by Snipershot
Thanks! Its weird that it worked fine with the old top, and doesnt work after the new top got installed
Joe
If you remember you held the close button until the light went out on your instrument pod indicating closed, microswitch at latch had nothing to do with it. What you can try is open the top and release the 2 cables at the back. This should allow the transmissions to go full stop and turn the light off. If this works then the new top may relax enough or you might have to adjust the cables a little.
