Thread: Cel 1124 & 1126
Old 07-31-2017, 11:07 AM   #12
Toppy986
Toppy
Toppy986's Avatar
THe Purge valve stuck open should cause a CEL and code. P0446 ,certainly a P044x and Durametric would have identified this fault.
https://www.renntech.org/forums/topic/36978-code-p0446/?_fromLogin=1
If propane or other techniques do not work,it is because they are not being applied in the leaking location(in this case under the fender liner!)
you are correct, I did have code P0441, however I did not wait for the system to run a full diagnostic reset between clearing codes after i tried somthing with the intake, the evap code didn't show up until the evap system reset, which I believe is the last system to set, just want to make sure the same mistake is not being made that i did, with clearing the codes
1999 Boxster
Arena Red/Graphite Grey Interior/Black 03 Top/550 All Red Tail Lights
Toppy986 is offline   Reply With Quote
