Old 07-31-2017, 05:41 AM   #10
Filastein
Filastein's Avatar
Originally Posted by mike914 View Post
HEllo and thanks for the advice
I like the ides of drilling a hole into the plate without removing it
Ant idea where the hole should be located?
Also I will be going with the factory spec lube thanks
Mike
Just preformed this change for the first time last week. Drilled a 2-1/2" hole in the plate. Centered it side to side and from front to rear, I placed it between the roughly 8mm existing hole and the rivet aft of it. Worked great. There are pics on this board of where the hole goes.
2 0 0 1 S
Filastein is offline   Reply With Quote
