Old 07-30-2017, 09:46 PM   #25
Silber
And if you have 14 psi negative pressure in a crankcase and you have 14 psi positive pressure in the IMS tube, the pressure difference is 28 PSI.
I am thinking this is not a problem, freeze plugs are often used in oil galleries and oil pressure can be higher than that.
I cannot seem to find any engineering data for freeze plugs on the web as far as what kind of pressures they can hold. I may have to experiment. I have feelers out for a damaged IMS shaft that I can plug and pressure test, hopefully I will find one before too long.
Silber
2002 Boxster S - Silver/Boxster Red
Coilovers - LSD - CAI - High Flow exh. - F&R Adjustable Sways
LN 3.2 to 3.8 - parts acquired, pending assembly and tuning
Silber is offline   Reply With Quote
