Old 07-30-2017, 02:53 PM   #28
Rotmilky
Originally Posted by lskolnick View Post
I just resolved this exact problem today. Master cylinder replaced twice before determining it was a bad ABS pump. $50 on eBay and some labour, and she's all fixed up. Make sure you get the correct part number. There are several over the years. Just match your existing pump.
It's odd that there really hasn't been any threads about a bad ABS causing this issue. I did a ton of searching and only found an offhand comment in a 987 thread. So, I figured it was quite rare. Then you post you had the same problem recently and Mueltone has PMed me that he think he has the same issue. So...there are more ABS problems out there than I expected.
I wonder if the ABS units are rebuildable? I worry a bit that my replacement unit is that same age and will start to do the same thing in the near future.
V.H. Whitley
Owner of Waaay too many vehicles
Non Porsche :1959 International B120, 1960 International B120, 2015 BMW M3
Porsche: 1997 986, 2001 986S, 1968 911L, 1968 911S, 2005 911, 1984 928, 2008 Cayenne S.
Rotmilky is offline   Reply With Quote
