Old 07-30-2017, 08:25 AM   #8
kk2002s
kk2002s's Avatar
Originally Posted by mike914 View Post
HEllo and thanks for the advice
I like the ides of drilling a hole into the plate without removing it
Ant idea where the hole should be located?
Also I will be going with the factory spec lube thanks
Mike
I used a flash light and pilot holes. There is a hole already near to plug location. that will get you close shining light through whole and seeing where it is relative to the plug. Drill pilot hole, shine light repeat until the pilot hole is located at plug. Use pilot hole for your hole cutting blade bit add keep working at it until you get through.
***As several have said, before you drain, make sure you can loosen the fill plug FIRST***
Seal Grey
