Old 07-28-2017, 11:10 AM   #12
Silber
I expect that Silber has already seen this thread. It runs for about 250 posts and addresses some similar questions. Post #52 actually has a freeze plug in the diagram. It's worth browsing through if you are interested in this topic.
Another IMS bearing thread
I had not seen this link, about halfway through reading it, came upon this:
had not considered the pressure disassembling IMS shaft. Will have to think that one through. At first blush, I don't think the pressures will be high enough, but need to test exactly how high the pressures might be experimentally.
EDIT: the last two posts in the thread seem to indicate the IMS Solution uses a "blanking plate" to block air/oil from the ims shaft tube. Sounds very similar to what a freeze plug does, and would indicate that pressure inside the shaft is not an issue.
All I want to do is make the Porsche bearing last as long as a clutch does reliably. May not be possible. Nothing in that thread rules out that a plug might help the situation, however.
2002 Boxster S - Silver/Boxster Red
Coilovers - LSD - CAI - High Flow exh. - F&R Adjustable Sways
LN 3.2 to 3.8 - parts acquired, pending assembly and tuning
Silber is offline   Reply With Quote
