Thanks for that info and Nice Anniversary Model.
I have custom fitted 2 x 4x6" speakers into the storage box that are driven by each channel separately. The issue i believe is with the coupe amp vs the cabriolet that the rears are lower powered in the coupe. Hence i want to beef up the rear channel but seeing this thread boosting the entire system would be nice and keeping it OEM..
Im running the PCM1 satnav headunit and want to keep it original otherwise i would go Alpine 7" headunit and custom 6 challenge amp.
Just need to run a bit more research on replacing these resistors and what type i need to be safe and maybe give it a try.
