Old 07-23-2017, 12:55 PM   #10
thom4782
thom4782's Avatar
If you're going to continue to research this, find out first who Porsche sourced its bearing from. If you find out and compare specs, your choice may be better or not. If it/s dramatically better than Porsche's on all measures, then hopefully your choice will last at least as long or longer as the Porsche bearing does.
Keep in mind, there are lot's of folks out there whose opinions are just guesses. Porsche's and LN failure rates are well known after use of thousands of units and thousands of miles in the real world. Others are speculative. When faced with a potential $5K to $20K consequence of a failure, I'd suggest you let real world results guide your decision.
