No apparent effect on metallic rattle noise when applying pressure on clutch pedal. When the replacement pulley has arrived and I have the serpentine belt removed to replace the pulley, I can certainly try pushing/pulling on the crank pulley to see if I can make the thing move more than the thrust bearing wear limit.
2001 Boxster
